Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Drucker - Prager Material Definition
1 REPLY 1
406 Views, 1 Reply
Good morning everyone.
I would like to run a simulation of earth under influence of gravity. For this I made a simple model in the shape of a cuboid first.
I run a simulation with nonlinear material behaviour and an elastic isotropic material to check if the constraints are correct. This simulation runs without any problems.
Next I changed the setup of the element definition to Drucker - Prager and used a self-defined material model (material model was set to Drucker - Prager).
This model does not converge.
I suspect the error in the material properties due to the fact I have not changed anything else.
Sadly I do not know which material properties are absolute necessary to input. For this I tried some different values but no combination worked.
(I remeshed the model but this does not help either.)
A quick look into summary and log reports showed no errors. The convergence was just not reached in time.
Maybe someone has experience with Drucker-Prager analysis or could tell me some material properties which should work?
1 REPLY 1
Attached you can find my simulation if needed.
(I was not able to upload the archive of the simulation so I uploaded a zip - file.
I hope this does work too.)
