Solved by John_Holtz. Go to Solution.
Can NOT find the file you attached here.
Usually, drop test is simulated with a MES model in Algor.
Please make sure there is not any red-cross in your element/part/model settings.
hello ,
I am on MES. I configured material, mesh . plane and gravitiy. I push the analysis button and nothing happens.
I am trying to attach a file maybe someone can see something wrong in my setup. then i get a message about one warning in the analysis and thats it. nothing happens
I think i found the warning, it says "Stop:contact walls not permited for linear problems"
If there was a warning, it will appear in one of the processor log files. Please click on the "Report" tab (underneath the browser) and expand the branch for the "Processor Log Files". The warning will be in either the log file or summary file or both.
Many of the warnings and errors are described in the documentation. See .
If the above doesn't fix the problem, then please create an archive of the model ("File > Archive > Create") and attach the archive to the discussion group. The .FEM file that you provided earlier is not the complete input, so it is of no use in this situation.
Hello John,
Thank you for your reply. I cant solve the problem although I have followed the tutorial step by step from the following link:http://resources.autodesk.com/msd/Autodesk_Algor_Simulation/How_Tos .My file is 2M and i cant post it here.
Do you have an ftp maybe ?
This issue is very imporant for us, Benny my manager sent you an email yesterday so we can get training from Autodesk in Algor. I hope you mail him back.
Best Regards,
Dan Margulius
Omnitech
israel
Hi Dan,
The warning message "contact walls not permited for linear problems" indicates that the MES analysis is configured to use "small displacement" theory for the calculations. (Small displacements problems are usually linear in nature.) Since you have an impact plane in the analysis, the MES solver assumes you are doing some kind of drop test which implies large displacement and motion.
So, go to the Element Definition for each part and change the "Analysis Type" drop-down from "Small Displacement" to "Large Displacement".
If a majority of your MES analyses requires large displacements or nonlinear effects, use the "Tools: Options: Analysis" tab and set the "Use large displacement as default for nonlinear analyses" option to set the "Analysis Type" default to large displacement.
