When the SimJobManager is suppose to start download partial results in an event simulation? It tells me that the simulation is 10% done but I haven't have any feedback since the start of the simulation, and if I open the case from simulation job manager in the Mechanical it doesn't show me that the simulation is running.
Solved by Andrew.Sartorelli. Go to Solution.
Hi RAALVM,
Results should start downloading at the 80% mark. The percentage complete can be a bit deceptive, its more like a step completion. The 10% mark is the solid meshing stage, so if your analysis is stuck there, it may be looping through the solid mesh retries that were implemented in the 2015 release. I would recommend cancelling the analysis and checking the solid mesh beforehand, this can be done using the "Check Model" command on tha analysis tab of the ribbon.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Thanks, for explaining it. But as you said is a bit deceptive, woudn't be more useful to have some sort of different messages to have a feedback of what it is going on? If I close the mecanical simulation program and open it again it doesn't show that the scenario is running it shows like the analisys is not started, and I can submit it again.
In the Simulation CFD you have a messaging system that shows what is solver doing, like meshing, solving, etc.
