Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Downloading results form Cloud
3 REPLIES 3
457 Views, 3 Replies
When the SimJobManager is suppose to start download partial results in an event simulation? It tells me that the simulation is 10% done but I haven't have any feedback since the start of the simulation, and if I open the case from simulation job manager in the Mechanical it doesn't show me that the simulation is running.
3 REPLIES 3
Andrew.Sartorelli
Hi RAALVM,
Results should start downloading at the 80% mark. The percentage complete can be a bit deceptive, its more like a step completion. The 10% mark is the solid meshing stage, so if your analysis is stuck there, it may be looping through the solid mesh retries that were implemented in the 2015 release. I would recommend cancelling the analysis and checking the solid mesh beforehand, this can be done using the "Check Model" command on tha analysis tab of the ribbon.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Andrew Sartorelli - Autodesk GmbH
in reply to: Andrew.Sartorelli
Thanks, for explaining it. But as you said is a bit deceptive, woudn't be more useful to have some sort of different messages to have a feedback of what it is going on? If I close the mecanical simulation program and open it again it doesn't show that the scenario is running it shows like the analisys is not started, and I can submit it again.
In the Simulation CFD you have a messaging system that shows what is solver doing, like meshing, solving, etc.
Andrew.Sartorelli
I certainly agree that the feedback could be better for Sim Mech 360 analyses. With a local analysis you will see that feedback in the Simulation Mechanical interface rather than the job manager. I'd recommend posting to the Simulation Mechanical IdeaStation, a forum monitored by the product manager, so other customers know this idea has been suggested.
http://forums.autodesk.com/t5/ideas/v2/ideaexchangepage/blog-id/81/tab/popular
