It is not possible to download Simulation Mechanical 2015. If i try browser download, the error message "File not found." " occures. The download with the autodesk download manager is also not possible. Same with the install now option.
In case you are trying download it from Education Portal, I've informed Autodesk Education representative just two days ago.
Retry in the next few days.
Hello corleone13375,
Welcome to the community.
Could you please re-attempt the download using the below direct link:
Autodesk Simulation Mechanical 2015 Win 64bit
I have the same problem with download. Link to Simulation Mechanical 2015/Simulation Flex is not working.
I've tried http://edutrial.autodesk.com/SWDLDNET4/2015/SPROLS/DLM/SimFlex_2015_Multilingual_Win_64bit_dlm.sfx.e... for Flex
and http://edutrial.autodesk.com/SWDLDNET4/2015/ASMES/DLM/Autodesk_Simulation_Mechanical_2015_Multilingu... for Simulation Mechanical.
For both I've got "File not found error".
Instal now/download now/Virtual Agent are not working too.
Hello all,
Here is the Autodesk Simulation Mechanical 2015 64-bit download link. This link will expire in 30 days from today's date. If you need a download link after this one expires, please contact customer service.
Thank you!
Autodesk Simulation Mechanical 2015 64 bit R1
@Anonymous wrote:It is not possible to download Simulation Mechanical 2015. If i try browser download, the error message "File not found." " occures. The download with the autodesk download manager is also not possible. Same with the install now option.
