Snooped around the software's tutorials and help section, but I can't figure out what analysis to use and an example of how to set up the analysis as well as how to display those results. I had an old thermal analysis that I tried to figure out if there was a means of displaying the expansion/shrink of the part, but the only things I found were the "long/short ratio", warp angle, etc. The numbers didn't make sense. For instance, the long/short ratio displays in mm/mm, and the value was 15 mm/mm, which definitely doesn't make sense for expansion of a metal object for a heat rise of 35 deg C.
A little help, please?
Hi John,
A thermal analysis only calculates temperatures and heat fluxes. To get displacements, whether due to applied forces or thermal expansion, you need to perform a stress analysis. Here are two pages in the help that should get you started:
