im using simulation MULTIPHYSICS 2013. when i run analysis the fluid elements turn white after few seconds and all the colour disppears though it is present in the legend. im using the inventor 2013 too. the same happens with the streamline view too. please help me out. please.
Hi cmghosh1991,
From the screenshot it appears that you are using either Windows 8 or Windows 8.1, Autodesk Multiphyics 2013 only supports up to Windows 7. Autodesk Simulation Mechanical 2014 supports Windows 8 and Autodesk Simulation Mechanical 2015 supports Windows 8.1. The fluid flow analysis components of Autodesk Multiphysics were discontinued with the 2014 release of Simulation Mechanical, if you are intersted in performing CFD analysis on Windows 8/8.1 I recommend that you take a look at Simulation CFD 2015.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
