Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor
0 Kudos
Determine Torsional stiffness/rigidity
470 Views, 4 Replies
05-16-2013 10:44 AM
Hi
I would like to determine the torsional stiffness or a non-circular, constant cross-section part. I am trying to optimize the composition/cross section of a simple airfoil and need to examine the impact of changes to the cross section on the torsional stiffness. How can one determine torsional rigidity/stiffness?
Shannon
129 Kudos
Re: Determine Torsional stiffness/rigidity
05-17-2013 06:45 AM in reply to: sapayne
Could you apply a torque to twist it, and then measure or calculate the angle of twist?
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
Simulation Mechanical user since Dec 1997
Active Contributor
0 Kudos
05-17-2013 08:05 AM in reply to: sapayne
This is precisely the work around I've applied. Thanks for the feedback :]
Active Contributor
0 Kudos
05-17-2013 08:13 AM in reply to: AstroJohnPE
On a similar note, when applying this method to irregularly shaped torsion members, is there a simple means of precisely determining the neutral axis?
Shannon
Active Contributor
0 Kudos
05-21-2013 02:17 PM in reply to: AstroJohnPE
Do you have a recomended means of applying pure torsion?
At the moment I have applied a torque to a selected surface, however It appears that this may be applying a torque to eash individual node and I am not certain that the part is experienceing pure torsion.
