Good day.Could not be clarified: what coefficients need to ask for the calculation of creep? (Specifically, what values should be a factor of 1 and 3). I use the "power law of Norton."
Ecreep = A * sigma^n * time^m
A = 1.4e-6 (coefficient1)
n = 1.0 (coefficient2)
m = 0.2 (coefficient1)
If so set the coefficients, then results do not match.
образец 15х15х60 см
приложенное давление 1 МПа
Ec = 30 000МПа
nu = 0.2
без учета ползучести -- деформация по Z 3.33е-5, cмещение по Z -- 0.02мм
c учетом ползучести -- результаты некорректны
ниже приведен график (теория) зависимостей Eps(t) и Ecreep(t) с подобранными коэффициентами A=1.125e-5, n=1.0, m=0.094 (уточнил), но результаты вычислений у меня с ними не сходятся.
sample 15x15x60 cm
applied pressure of 1 MPa
Ec = 30 000MPa
nu = 0.2
without creep - deformation of the Z 3.33e-5, Displacements on Z - 0.02mm (ok)
c considering creep - the results are incorrect
Below is a chart (theory) and the dependence of the Eps(t) and Ecreep(t) with the coefficients A = 1.125e-5, n = 1.0, m = 0.094 (more accurate), but the results of calculations, I do not agree with them.
The model: https://www.dropbox.com/s/pmxr7qlna40a0cm/15x15x60.ach
