Discussion Groups
Simulation Mechanical and Multiphysics
Active Member
dodgeboy_cc
Accepted Solution
Create a 2D axisymetric model from a 3D inventor file
368 Views, 3 Replies
03-07-2013 01:37 PM
I was wandering if you could import a 2D sketch into multiphysics from Inventor or Autocad. I normally import 3D models into multiphysics fro inventor but I want to model a fluid flow using a 2D sketch. Is there any way to use the 3D model to get this sketch or import a 2D sketch into multiphysics.
Please use plain text.
Distinguished Contributor
ilyas
Re: Create a 2D axisymetric model from a 3D inventor file
03-07-2013 07:37 PM in reply to: dodgeboy_cc
I am not sure about AutoCAD, but if you are using inventor, I dont think that the Launch Active Model works for sketches. Instead, you might need to export it to some other format such as .dwg or .igs and open it from inside Multiphysics.
Active Member
dodgeboy_cc
03-08-2013 09:04 AM in reply to: ilyas
Thank you that worked. Do you were I can find tutorials for 2D simulations. Everything I have seen on autodesk website is 3D
*Expert Elite*
AstroJohnPE
03-08-2013 10:56 AM in reply to: dodgeboy_cc
The "Examples" section of the Help documentation contains a lot of 2D examples.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
Simulation Mechanical user since Dec 1997
