Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Convergence monitoring graph?
2 REPLIES 2
Duckjae_Lee
476 Views, 2 Replies
Hi All,
Could I check convergence status with graph for CFD analysis in ASIM(Algor)?
I found like below information.
Help : For all of the iterative solver options, if the Output Convergence results for Monitor checkbox is activated, you will be able to view a graph of the convergence results throughout the analysis.
So I checked "Output convergence results for Monitor" checkbox, but couldn't see any graph in Algor.
Is there anything wrong? or is there any way to display it?
Thanks and regards,
Duck Lee
2 REPLIES 2
Joey.X
in reply to: Duckjae_Lee
In ASIM(Algor) CFD , the checkbox of  "Output convergence results for Monitor" is used for output the convergence history in text format, it does not have convergence graph (convergence history curve) output in last release(V2012). I agree that the statement in help file may mislead.
BTW, the convergence graph(convergence history curve) output is under development and probably be available in coming release.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
Duckjae_Lee
in reply to: Joey.X
Thank you for your reply.
Duck Lee
