Discussion Groups
Simulation Mechanical and Multiphysics
New Member
0 Kudos
Contact error! Help please!
149 Views, 1 Replies
04-25-2013 07:59 AM
I'm trying to perform a linear static stress analysis between parts which are bolted together using the 'Bolt' function in CAD additions combined with surface contact as the parts are not bonded or welded together.
When I run the analysis I get an error message saying to "use SSAP0G or SSAP0GC for models containing gap or contact elements". I am using Windows and these seem to be instructions for performing the analysis on Linux. I cannot find a dialog box or anything to change this parameter
The analysis runs fine when I choose bonded contact.
Any help would be greatly appreciated!
Pete
127 Kudos
Re: Contact error! Help please!
05-01-2013 08:55 AM in reply to: pete.large1
Hi Pete,
  1. What version of the software are you using? ("Help > About" or the header of the log files that are produced by the processor and viewable from the Report environment.)
  2. How are you running the analysis? Through the interface? By using the Scheduler capability? From a command prompt or batch file? Something else?
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
Simulation Mechanical user since Dec 1997
