I have two mid plane surface which i want to connect together. The plate/shell type of mesh is applied to all surfaces (Becasue of surface model).
could you please explain me how cant i connect two surface together (there is gape between two surface becasue of they are mid plane surfaces of two solid parts_Please check atteched picture) the bottom one is fixed and the force is applied on the bolt.
Solved by AstroJohnPE. Go to Solution.
Hi Vikas,
If you are performing a linear analyis, then try the "Draw > Design > Contact Elements" command. This will draw line elements (on a new part) between the two surfaces. Use the option to limit the length of the elements to a length slightly greater than the distance between the two surfaces.
Then, how you define the elements depends on how you want to consider the two parts to be connected. If you want to consider them rigidly connected together, then make the element type Beam and give them relatively stiff properties. If the two parts are bolted together and you want to consider the potential separation of the two surfaces, define the element type as Gap, but make a few of them (4?) beam elements to represent the bolts and to keep everything together.
Hei
John
Thank you very much for your reply,
In the same surface model i have some doubt. Could you please tell me what does it mean by " ! " sign in CAD mesh options.
For information, i am performing static linear analysis. and the model type is surface model.
could also please tell me what kind of contact or element should i put between two plates as shown in 2nd figure? is it ok if i put the contact elements in bwtween (as you replied first time) ?
Those two solid plates are weled together from edges all around. as you can see in 2nd figure i have put midplane surfaces so now i have gape between those two surfaces.
Thank you in advance
Vikas
Hi Vikas, here are some options.
About the "!" on the parts, it is indicating that the software thinks something is wrong. If I remember correctly, you can right-click on the line and choose one of the commands (mesh results?) to see what the message is.
But remember: the software does not know what you are doing. It just has a set of rules that it must follow. It does not really know if a warning will cause any problems. For that matter, it does not know that a model with no warnings or errors is a good model. What counts is what the model looks like in the Results environment (any missing elements, either on the surface or inside a volume?), what the applied loads look like (are the pressure arrows in the proper direction, etc), and what the results indicate (do parts come apart or pass through each other? Do the reactions equal the expected load?, etc).
Hei
John,
THANK YOU VERY MUCH for you very well explained reply .
I will try as you replied and get back to you if i will have any more question.
Thank you again
Vikas
Hei
I have one more question about gravity,
I want to apply gravity in 3 direction , I meant my gravity should work at 20 degree in X-Y plane (20 degree angel with -Y axis in counter clockwise direction) and 10 degree Y-Z plane (10 degree angel with -Y axis in clockwise direction)
and for that I have applied multipliers as (I want to set standard gravity 9810 mm/s2),
X= 0.34202
Y= 0.92541
Z= 0.16317
But once I put given multiplier in gravity dialog box, and click OK, the gravity symbol (Apple) becomes inactive.
Could you please explain me why?
(if I put anyone multiplier as 1, regardless rest of two multipliers it shows gravity active. Can you please tell me why?
Vikas
It sounds like a bug to me. I suggest that you submit it to technical support so that they can write a bug report.
I think it is highly unlikely that it affects the analysis at all, but you should do a simple test to make sure. This test would also be important for tech support to evaluate the importance of the bug.
