Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Combining Surfaces
2 REPLIES 2
mikebscott
543 Views, 2 Replies
Combining Surfaces
I am running an electrostatic field strength and voltage simulation for a MEMS device, but am having a problem specifying the "Invoke Force/Charge calculation" surfaces.  I have a lot of surfaces that I need information for, and was wondering if I could specify only one surface.
I saw in a tutorial, located here, in which multiple surfaces are combine into one surface.
I have been looking for a long time on google and these threads, but have not found any way to do this.
Thanks a lot for your help,
Mike
2 REPLIES 2
John_Holtz
in reply to: mikebscott
Hi Mike,
Select the lines that you want to change. The easiest method is to first select all of the surfaces ("Selection > Select > Surface" while holding down the Shift key), then select the lines on those surfaces ("Selection > Subentities > Lines").
Change the surface number of the selected lines. ("Draw > Modify > Attributes")
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
mikebscott
in reply to: John_Holtz
Thanks a lot,
You have saved me a lot of time!
