Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
CFD error message (about convergence)
2 REPLIES 2
ryu
585 Views, 2 Replies
Hello
Analyzing, I met warning message.
But I don’t know what to means.
View statistics
**** Maximum attempts exceeded
**** The solution did not meet convergence criteria,
try the following options:
(1) reduce the loading
(2) relax the convergence criterion
(3) increase the number of iterations
(4) use custom time with different value of increment
(5) try transient fluid-flow analysis (flow04)
(6) contact ALGOR service at service@Algor.com
please answer me, to do setting option or how to solution
2 REPLIES 2
PipePakPat
in reply to: ryu
ryu@daoudata.co.kr,
The message you received indicates that the process used an iterative solving technique and could not converge on a solution within the iteration limit. The processor then made 6 recommendations. The only revision to these six recommendations that I would offer is the sixth, which should suggest to contact for technical support. Otherwise, the message is generic. This issue may require examination by technical support to make relevant suggestions.
Pat Tessaro, P.E.
Autodesk Inc.
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
Joey.X
in reply to: PipePakPat
Except above suggestions, the typical modeling issues for the fluid flow divergence or oscillation are
- Use steady state solve true unsteady problem (such as vortex shedding problem);
- Illegal boundary conditions
- Boundary layer mesh at flow inlets and outlets
- Forget turning on turbulence for turbulence flow(user needs to check the Reynolds number)
- Poor mesh (usual too coarse) with no or few interior fluid nodes in narrow channels.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
