Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Cannot load trial version of autodesk simulation error 2324 Help please
2 REPLIES 2
388 Views, 2 Replies
Hi
I have been trying to install a trial version of autodesk simulation but when it is nearly complete it give an error 2324 cannot access C:\Window\SysWOW64/msexch35.dll. Please help
Pc specs
Proc  -  AMD Phenom x6 II 3.3GHZ
Grap  - Nvida 460GT Ninja
Mem  - 8G ram
OS    -  Window 7 64bit sp1
Regards
Desmond
2 REPLIES 2
John_Holtz
Hi Desmond,
A number of questions come to mind.
  1. does msexch35.dll exist in that directory?
  2. try to register that file. Use My Computer/Windows Explorer and surf to the directory. Locate the file msexch35.dll. Go to the "Start" button and choose "Run". Type REGSVR32 space. Drag the file msexch35.dll to the "Run" window, so the full command will be REGSVR32 C:\Windows\SysWOW64\msech35.dll.  Press the OK button. Does the file register successfully?
  3. try to disable any virus software before starting the installation.
  4. I do not know if it is related to the User Account Control settings (UAC), but you might want to check what that is set to and try a lower setting.
Good luck.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
in reply to: John_Holtz
Astrojohn
I have tried everything you suggested, please see error message attached, my window says the msexch35.dll not compatable ?
