Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Can use some advise about a projection method
1 REPLY 1
mechamania
240 Views, 1 Reply
I have a template part that contains several planes with sketches on it.
On one of these sketches I need a projection from another sketch by rotating it on some axis.
To accomplish this I used a Revolve feature in combination with a Project Cut Edges.
So in fact making a solid. But because this is a template I do not really need the solid so I set Visibility off.
But in my FEA analysis this solid is causing contacts and it shows up in the simulation result.
I would like to get rid of this solid.
So how can I project from one sketch (on some plane) to another sketch (on another plane) by rotating around some axis? Is that possible without creating a solid?
I hope someone has some good advice.
Note that I can not attach the files here because of IP issues.
Thanks in advance.
1 REPLY 1
For the FEA analysis, are you using Inventor Professional or Simulation Mechanical?
In Simulation Mechanical, you can just suppress the construction part by right-clicking it in the browser and choose the suppress command.
I don't know how to suppress parts in inventor. What I can think for you is to use the 3D model > Surface > Eelete Face tool and use the select lump or void option.
Regards
Ilyas
