I have currently downloaded a free trial of Autodesk Simulation. After it finishes downloading it opens and then asks me what program I want to use to install it. I found the Akamai Control Panel and used that but nothing happened. I uninstalled Akamai and reinstalled it and it still won't work. I have the file downloaded but there is no extension.
Solved by whiteskulleton. Go to Solution.
I just figured out the problem. I renamed the file and it took away the .exe so it didn't reconize it. I renamed it and added a .exe to the end and that solved everything.
