HI,
I have following problem:
I am planning with 2D analysis.
I have created two parts importing linework form Autocad.
I can mesh them and run the analyse.
But if I delete mesh of one part or both I can not see lines that create boundary of this elements.
I have tried with different visual styles, visibility of parts, isolation ....
What I should do to make this lines visible?
Cris.
Hi Cris,
How did you delete the lines? The two options come to my mind:
I have not deleted lines at all.
What I did was: selected mesh in the tree and chose "delete" from context menu
Lines are listed in the tree view.
I have tried every possible option in View menu. Nothing had a effect that would be showing the lines.
I discovered that if I do following procedure lines are visible (but this are not original once)
In tree view I select plane on which this invisible lines are and select "copy to plane..." from context menu. I copy them to XY (originally they are on YZ).
After that I copy again from XY to YZ and this new lines (this copied twice) are then shown on screen.
Is this normal?
Cris
