Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Can I create a contour plot of pressure?
4 REPLIES 4
641 Views, 4 Replies
How do I create a contour plot of the pressure in the material?  I can't find it in the menus…
Petr
4 REPLIES 4
S.LI
If you are talking about stress analysis for structures, I would say "no". Stress/strain/displacement etc. make more sense in solid mechanics.
If you mean "CFD", I think pressure output should be there.
For other analysis types, I'm not sure. Probably not.
If this response answers your concern, please mark it as "solved".
in reply to: S.LI
What about the "custom results" dialogue? Wouldn't that be useful for something like this? I have defined the pressure variable as shown in the attached snapshot of the dialogue, but nothing gets displayed.  Am I doing something wrong?
Petr
John_Holtz
It looks as if the Custom Results menu is broken in the ribbon interface. You can define the result, but you cannot choose to display it. Smiley Frustrated
To display a custom result, you need to switch to the old style menu ("Tools > Options > Application Options" and uncheck "Ribbon Style" on the "General Information" tab).
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
in reply to: John_Holtz
Thanks.
P
