Hello Everyone,
I would like to report a bug: One does not simply show custom results with Ribbon interface.
Version I am using: Mechanical 2013
Bug steps:
1- Create model.
2- Set up model.
3- Run simulation.
4- Create custom results using Ribbon.
5- Results Contours -> Other Results -> Custom Results -> Manager
6- It must be calculated, so re-run simulation.
7- Try to select custom result Results Contours -> Other Results -> Custom Results -> Your result
8- Nothing happens.
9- Change UI to classic.
10- Results Menu -> Last line has your custom menu. Select it.
11- Voilà: Custom Resutls appear.
I understand that this is non critical and that there is a workaround for it, but this is quite annoying....
Thanks, and I hope I was helpful.
It's still the same in Simulation Mechanical 2015.
I was told last year that it was a known issue.
If it's a known issue, why not fix it?
Thank you for reporting this bug. We are working on a fix for our upcoming release.
Sualp Ozel
Autodesk Simulation Mechanical Product Manager
