Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Bolted plates with surface to surface contact - friction activated
0 REPLIES 0
Message 1 of 1
410 Views, 0 Replies
Good day,
I would like to ask the following question:
my goal is to derive the forces acting on a bolt that holds two plates together.
In a simple model I put together two steel plates (brick) joined with a bolt preloaded. I applied a surface contact between the plates, I fixed a plate and I applied a horizontal force on the other plate.
The preload on the bolt is very high and the coefficient of friction is such as to generate a resistance greater than the force applied this should prevent the sliding between the plates and the bolt should not be stressed in shear.
The results show instead a shear force on the bolt equal to the force applied.
The analysis is of the "linear satic stress" type
I made a mistake or forgot to set some parameter?
Thanks in advance.
0 REPLIES 0
