Hi
I need to learn the basic equations & theoretical back up (only for Static stress with liniear materials model) that are working behind Autodesk Mechanical.
I will be very gratefull if you give me the links from where i may get basic mathematical background of FEA.
Thanks in advance.
Solved by zhuangs. Go to Solution.
You can use the "Online Help" and input the keywords in which you are intereted at the following link:
-Shoubing
