Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Basic question about Boundary Conditions
1 REPLY 1
andrew30
486 Views, 1 Reply
Hello all,
I am new to Algor and would like to know is how you go about defining surfaces for pressure loads on a complicated geometry in Algor. I would like to apply the load on only a portion of an existing surface on the part for example. Thanks in advance for any advice.
Andrew
1 REPLY 1
S.LI
in reply to: andrew30
You can split the surface in CAD package, if it's from there.
Another way is to change line attributes.
1.) select all lines on the portion with surface loads;
2.) change their attributes to make a new surface.
If this response answers your concern, please mark it as "solved".
