Nodal temperatures of cooling air leaving an enclosure are not uniform. Is there an easy way to get an average nodal temperature at the exit plane?
In result environment
- Select surface(the exit plane in your case), right click to “select sub-entities”/Nodes, this make you select all nodes on this surface.
- Right click to “Inquire result”, change to “mean” in Summary selection, it will show the average temperature for all nodes on this surface.
