In result environment
- Select surface(the exit plane in your case), right click to “select sub-entities”/Nodes, this make you select all nodes on this surface.
- Right click to “Inquire result”, change to “mean” in Summary selection, it will show the average temperature for all nodes on this surface.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
