Simulation Mechanical and Multiphysics
Employee
PipePakPat
Re: Automation?
08-09-2012 10:37 AM in reply to: smm.144
One can either create "sketches" within Autodesk Simulation Mechanical or Multphysics (Algor) within the YZ plane, then mesh those outlines using the 2D Mesh Generator and analyze as 2D elements.  This is common and a powerful method in reducing analysis time while providing cross sectional results detail.
It is also possible to create and export sketch data from other CAD packages as DXF or DWG, then open those files directly into Simulation.
Pat Tessaro, P.E.
Customer Support Engineer
Autodesk, Inc.
285 Kappa Drive
Suite 250
Pittsburgh, PA 15238
Please use plain text.
