Discussion Groups
Simulation Mechanical and Multiphysics
Active Member
oldtobacco
Re: Autodesk Simulation
05-04-2011 09:19 AM in reply to: oldtobacco
My memory arrived, I installed it, I checked system info - 2.5GB check, and loaded simulation 2012 and I still recieve the same error message.  Before the program is loaded fully and before I can select a model to open I am told the program has encountered an error and is shutting down.
Could there be a corrupt registry value?
During installation I entered the serial number and product key but my autodesk account still says the software is not activated, could this be an issue?
Let me know,
Jeff
Please use plain text.
Active Member
oldtobacco
05-04-2011 08:18 PM in reply to: oldtobacco
Another interesting issue is that I cannot log into my account without changing the password and using the 'take me to the website' button.
Is the amount of memory in the videocard a possible culprit?
Any help is appreciated.
Jeff Janert
Employee
Joey.X
05-05-2011 06:26 AM in reply to: oldtobacco
Try this trick to see if it works for you.
This might be related to registry mess up issue of Autodesk simulation Multiphysics v2012 installation, here is a trick that you can clean Windows registry for either 32 and 64 bit system.
(1) Download Msizap.exe from Microsoft website (free)
http://msdn.microsoft.com/en-us/library/aa370523(v​=vs.85).aspx
(2) log in as ADM user with full power, and run either one of the command from DOS prompt
(64bit)  MsiZap.exe TW {9C323B87-596F-2012-B164-A8E126A75E02}
(32bit)  MsiZap.exe TW {9C323B87-596F-2012-B132-A8E126A75E02}
(3) Reinstall  Autodesk simulation Multiphysics v2012
BTW, if you have trouble to get MsiZap.exe, let me know.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
Employee
SaMurgie
05-06-2011 12:01 PM in reply to: Joey.X
The graphics card could cause something like this.  Note you can turn off hardware acceleration which may help by going to
Tools->Application Options->Graphics->Hardware
and then clicking off the checkbox for  Enable OpenGl hardware acceleration
This could help.
What graphics card do you have and how much memory does it have?
Sam
Active Member
oldtobacco
05-06-2011 09:38 PM in reply to: oldtobacco
I have solved the problem.  The issue is that the Quadro FX5200 video card was unsupported, I never thought this would be an issue since it is a CAD card, it is an old card but still...  I switched it with the card that preceeded it and everything runs fine now.  Thank you for all of your assistance.
Jeff
Murilo.h.r
boundary layer in Autodesk Simulation
09-20-2011 07:35 AM in reply to: oldtobacco
Can someone help me find, how do I insert a 10mm mesh boundary layer in unsteady fluid flow in Autodesk Simulation
larb_10
01-13-2013 06:26 PM in reply to: Joey.X
Hi Joey.X,
Is there a similar way I can remove any registary mess for Autodesk Simulation Multiphysics 2013. I have had an issue with my installation. I have uninstalled as cleanly as possble but I am still not able to install it again. The installer is picking the program up as being already installed even though its not in the list of installed programs in Control Panel.
Sorry to drag this up in an old topic, but need to get it sorted out.
AstroJohnPE
01-15-2013 06:42 PM in reply to: larb_10
Hi larb_10,
I will contact my former co-workers at the Pittsburgh office. I encountered the same situation, and they have a procedure to fix it. If I remember correctly, it is a "simple" matter of searching the registry to find the QUID number for the version that needs to be uninstalled, and then deleting that QUID from the registry.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
Simulation Mechanical user since Dec 1997
