Greetings.
I figured out a bug in Autodesk Simulation Multiphysics 2012. If I open directly a part .ipt in the program, when I generate the mesh, it simply gets frozen in the process and does not move from there.
When I go to Inventor and select the option "Start Simulation" on Add-in tab, with the same file, it has no problem on meshing process.
I do have the SP1 installed, so I think it's a new bug. Do anyone had this problem before?
Thank you very much.
Regards.
These models should be forwarded to Autodesk Product Support by submitting an issue from within the Autodesk Subscription Center.
