Autodesk® Simulation Mechanical Hangout: Performing Weld Analysis
Webinar: Performing Weld Analysis
Wednesday, July 2nd, 2014
You're invited! Autodesk® Simulation Mechanical™ users are gathering for the very first in a series of Hangouts designed to introduce you to the powerful features available in Simulation Mechanical. We'll help you make your models more accurate, efficient, dynamic, and improve the visual impact of your presentations.
In this session, Performing Weld Analysis, we will discuss the many ways welds can be simulated, from analysis on the welds themselves to simulating large welded structures and how to best approximate the connections.
Join the session via the Web! Here's when and how:
Date & Time: July 2nd, 2014 @ 11:00 AM EST
Location: https://www1.gotomeeting.com/register/983602161
Duration: 20-30 minutes of presentation followed by Q&A
Access Information: Please register prior to the event using the above link.
Don't miss this opportunity to learn about Simulation Mechanical’s advanced features directly from Product Support!
Presenters
James Kubli – Has worked in technical support for the past 15 years; from personal computer repair and business network troubleshooting to providing support to web based applications. Currently is the Knowledge Expert at Autodesk providing support for Simulation Mechanical.
