Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Autodesk Simulation Mechanical - fatigue analysis.
3 REPLIES 3
m4the0
913 Views, 3 Replies
Hello
I started using Autodesk Simulation Mechanical Software few days ago, and i have problem with my fatigue analysis. (It's my student project).
I try to describe my problem with simple example:
So i would like to make fatigue analysis of simple beam. (One side is fixed, second side is loaded)
I would like to apply two forces, one in y direction, and the other in z direction, but both have diffrent load curves. I am not able to see an options in autodesk mechanical fatigue wizard, to add two different load curves.
I have attached image, which help me to describe my problem.
3 REPLIES 3
ilyas_drawbridge
in reply to: m4the0
Try watching this, it might help you with understanding how the setup works.
Regards
Ilyas
m4the0
in reply to: m4the0
I have watched this, but it's only simple example with one load curve. I have to apply two force in different directions with different load curves.
AstroJohnPE
in reply to: m4the0
Hi M4the0,
My guess is that you did not set up your stress analysis with two load cases. One of the forces should be assigned to load case 1, and the other force assigned to load case 2. This is done on the dialog where you defined the forces, so edit one of the forces.
This will create two sets of results (load case 1 and 2) in the stress analysis which the fatigue wizard can then add together using the load curve you define in the wizard.
