Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Autodesk Simulation Mechanical 2014 - Can't solve assembly with surface contact
2 REPLIES 2
1030 Views, 2 Replies
Hey
I have a assembly of a universal joint  which I try to simulate in a static situation, and I solve for linear stress. I have some troubles getting some results when I use "surface contact" between my parts (see attached picture, set up). When I push simulate my computer just start solving and solving, but after 15 min. If comes up with some warnings, and after 8 hours it just keep repeating the same warnings. What is wrong? The funny thing is that it takes around 15 min. To solve the same situation just with bonded surfaces. And results looks very realistic
Best regards
Kaare Bek Hansen
Mechanical student at University of Southern Denmark
2 REPLIES 2
Stefan2653
Kaare,
Is the left linkage properly constrained where the shaft would connecto to it? If you don't have a translational constraint in X and Y there, that linkage will just flop around, resulting in the insufficient tie down error. When you bond the assembly, the left linkage is prevented from flopping and the solver will arrive at a solution, even without those translational constraints.
Stefan
in reply to: Stefan2653
Thank you for the advise.
