You want to see the structure response under an electrical load, don't you?
I will go MES analysis type if I understand you correctly.
1.) apply voltage to all nodes you want;
2.) Analysis parameters setup dialog -> Thermal/Electrical tab, select "model file" for "source of nodal voltages"; and assign it with an appropriate load curve index.
3.) Go to Load curves tab, and edit the load curve shape as you wish (such as sinusoid).
4.) then your model is good to run.
One thing worth mentioning here is that all electrical loads have to follow the same load curve.
Sorry, but the calculation of the electrostatic forces is based on a constant voltage.
If I understand your explanation, you want to apply Voltage = A * sin(frequency * time). I have no experience in this area (MEMS devices, electrostatics, electricity), so I do not know if it is appropriate to assume that the electrostatic force at the maximum voltage is equal to the electrostatic force when a constant voltage = A is applied. If that were acceptable, then you could calculate the electrostatic forces and use Mechanical Event Simulation (MES) to vary the forces sinusoidally.
The other factor to consider is whether the displacements are large enough that they affect the electrostatic force distribution. If so, then the electrostatic forces vary based on time (known) and displacement (unknown), so the entire process becomes iterative between calculating the electrostatic force and the displacement.
Good luck.
Generic electric field analysis can be simplified according to assumptions
(a) Transient electrical conduction
This is a fully transient analysis with time dependent term in governing equations.
(b) AC conduction
This assumes sinusoidal steady state, with converting current continuity equation into frequency domain; the governing equation is simplified to complex quantity, where two Poisson equations are to be solved.
(c) DC conduction
Steady state (or DC current) is assumed, and time dependent term in governing equation is dropped and the governing equation is simplified to Poisson equation. Refer to ASIM document here
Note that ASIM's electrostatic analysis can do (c) only. smceee's question appears located in first, in my opinon, it has no workaround because of different governing equations except user don't care the effect of time dependent item.
All,
Thank you for your responses. Is there any chance that an upcoming software update will address Transient Electrical Conduction? If not, any thoughts on a product out there that will allow me to import a model from Autodesk and run the analysis?
Also, I am trying to follow the other approach mentioned to see what the results look like. I completed Electrostatic simulations for several applied voltages and then used the results to calculate the expected resonator displacement given the applied DC voltage. I would like to apply these results to my model in a sinusoidal fashion to a specific surface over a certain period of time and determine the resulting displacement, again as a function of time and applied voltage. As this period of time more closely matches device resonance, the displacement should increase and the mode should closely approximate the mode I am trying to excite from Modal Analysis. I am curious to see if this is the case approximating the situation as mentioned.
Thanks again for any help you can offer getting this set up using MES or any other analysis mode.
Steve
