Can someone please help me in the right direction to figure out why my analysis is stopping? Here is the log file.
Autodesk Algor Accupak/VE Mechanical Event Simulation
Version 2011.00.00.0111-W64/X64 12-MAR-2010
Copyright (c) 2010, Autodesk, Inc. All rights reserved.
** Total available memory = 3707568 (KB).
** Options executed are:
NOMIN - NO optimization for matrix storage
RUN - Execute processor
STRAIN - Output strain data for Superview
DUPLEX - Duplex communication with tWAIT=5 seconds
PRRO - Output reaction force data, n=2
PRCD - Output contact diagnostics data
NUMNP DOF NEGL NEGNL MODEX NSTE DT TSTART IPRI IPSF
550473 000000 0 65 1 20 0.500E-01 0.000E+00 1 3
** Perform analysis
** Open output files ...
** Open temporary files ...
** Reading input file ...
PROGRAM VERSION: 201100000111
alg-win-x64.dll VERSION: 201100000111
algconfig-win-x64.dll VERSION: 201100000111
agsdb_ar-win-x64.dll VERSION: 201100000111
amgsolve.exe VERSION: 0360000000
Model=C:\Users\Jeff\Desktop\Final Mast Re-design with Fixed Plate Meshed Analysis.ds_data\1\ds
**** Model Unit System Settings:
Unit System : English (in)
Force : lbf
Length : in
Time : s
Temperature (Absolute) : deg F (R)
Thermal Energy : in*lbf
Voltage : V
Current : A
Electrical Resistance : ohm
Mass : lbf*s^2/in
No. of nodes = 550473 No. of equations = 1648077
Maximum no. of iteration = 30 No. of steps = 20
Convergence tolerance = 5.0000E-03
** Input elements...
** 3-D continuum element calculation, number of element = 8263
** 3-D continuum element calculation, number of element = 12263
** 3-D continuum element calculation, number of element = 12237
** 3-D continuum element calculation, number of element = 12273
** 3-D continuum element calculation, number of element = 373173
** 3-D continuum element calculation, number of element = 6187
** 3-D continuum element calculation, number of element = 12029
** 3-D continuum element calculation, number of element = 12127
** 3-D continuum element calculation, number of element = 13294
** 3-D continuum element calculation, number of element = 16172
** 3-D continuum element calculation, number of element = 20188
** 3-D continuum element calculation, number of element = 12284
** 3-D continuum element calculation, number of element = 16091
** 3-D continuum element calculation, number of element = 12270
** 3-D continuum element calculation, number of element = 12279
** 3-D continuum element calculation, number of element = 14571
** 3-D continuum element calculation, number of element = 13004
** 3-D continuum element calculation, number of element = 6027
** 3-D continuum element calculation, number of element = 324851
** 3-D continuum element calculation, number of element = 11615
** 3-D continuum element calculation, number of element = 18017
** 3-D continuum element calculation, number of element = 638
** 3-D continuum element calculation, number of element = 85140
** 3-D continuum element calculation, number of element = 1467
** 3-D continuum element calculation, number of element = 14654
** 3-D continuum element calculation, number of element = 12846
** 3-D continuum element calculation, number of element = 18852
** 3-D continuum element calculation, number of element = 4670
** 3-D continuum element calculation, number of element = 17282
** 3-D beam element calculation, number of element = 77
** Error (1)
** Job started : 2012-04-05 08:10:15
** Job finished : 2012-04-05 08:14:52
** Total elapsed time : 4:36 (minutes:seconds)
!! Program aborted !
Can you post ds.al file here?
Your log shows only 3G memory available. Not sure if this is enough.
Also, if possible, please try version 2012 or 2013.
I have 8Gb on this machine and have set it to use up to 80% of that. Do I need to upgrade?
** Perform analysis
Force : lbf
Length : in
Time : s
Voltage : V
Current : A
Mass : lbf*s^2/in
** Error (1)
As shown in your log, code only found 3.7G.
You can change the 80% to 100%, 200% or even higher.
This really depends on your model.
For example, isotropic elastic material model needs less memory than elasto-plastic model. 8 integration points per element needs less memory than 27 integration points.
16G should be ok, I guess.
