Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Analysis at interface point of transversely isotropic elastic bi-material joint
3 REPLIES 3
lincs2k9
789 Views, 3 Replies
I need to analyze a transversely isotropic elastic bi-material joint. Nickel and cobalt are two material which are used as a bi-material joint. I need to show continuity or same properties like displacement, normal and shear stress at interface or joint edge of this bonded material. Actually I need to show that at interface point those two materials satisfy boundary conditions and show same mechanical properties. Which autodesk simulation software can help me to analyze this matter? please give me some suggestion in this matter. I need it for my study.
3 REPLIES 3
Jaesung
in reply to: lincs2k9
Hi lincs2k9,
You can acquire necessary conditions by bonded contact between two parts in Simulation Mechanical.
Please check out the slides on Bimetallic strip simulation case in the linked ppt
Jaesung
lincs2k9
in reply to: Jaesung
thanks for reply. I think it will be helpful..........
AhmadAfifKhan
Can you provide any other link? That link appears blank.
