I need to analyze a transversely isotropic elastic bi-material joint. Nickel and cobalt are two material which are used as a bi-material joint. I need to show continuity or same properties like displacement, normal and shear stress at interface or joint edge of this bonded material. Actually I need to show that at interface point those two materials satisfy boundary conditions and show same mechanical properties. Which autodesk simulation software can help me to analyze this matter? please give me some suggestion in this matter. I need it for my study.
Solved by Jaesung. Go to Solution.
Hi lincs2k9,
You can acquire necessary conditions by bonded contact between two parts in Simulation Mechanical.
Please check out the slides on Bimetallic strip simulation case in the linked ppt.
Jaesung
