Does anyone know if Algor 14.3 will open a v12.10 file to read results?
Yes, we are living in the past. This is for a long term project which had calculations done 10 years ago or so. We have Algor 14.3 (though not currently running) and our the customer would like to know if we could read 12.10 files. Our IT feels we can get 14.3 running again since we had it working last year.- though it will take some support.
I'm not as far in the past as you. I still have Algor V.22 and it opens files I created in Algor V.19, V.20, and V.21 so I believe your situation should work. Files saved in V14.3 will not be able to be opened in 12.10. After you reisnstall your Algor V14.3 you may need to contact Autodesk to rehost the license file if needed. I had that situation occur and Autodesk was helpful rehosting the license. Good Luck
