Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Airfoil Wing Analysis in Algor?
1 REPLY 1
475 Views, 1 Reply
I was wondering if anyone knows the best way to apply a load or wind or temperature or something to generate results for analysis on a airfoil.
Any help on how to work with this software would be beneficial!
Thank you.
Tags (3)
1 REPLY 1
Joey.X
For fluid wind load,
- Make fluid domain (fluid part) and set up fluid analysis as external flow (make airfoil inside box and set appropriate BCs).
- Run fluid analysis to get fluid reaction force contributed from pressure and stear stress on surface(s)
- (In structure analysis) read fluid reaction force for stress analysis
For temperature loads, do thermal or coupled fluid/thermal analysis first to get temperature distribution and apply as loads in structure analysis.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
