Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor
benalain
adding bc to prescribed displacement
620 Views, 10 Replies
10-15-2010 12:25 AM
Hi
I would just like to know how is it possible to add a bc to a node where there is still a prescribed displacement (of course in another dof).
Each time i try, i have the error message saying : prescribed displacement non active
Thanks!
Please use plain text.
Employee
S.LI
Re: adding bc to prescribed displacement
10-15-2010 05:06 AM in reply to: benalain
BC and PD are allowed to be applied on different DOFs of a node.
I bet your model needs double-check.
If your model is complicated, you can create a simple one ( maybe just one element) to see if there is still the same problem.
Of course, you are also welcome to share your model here.
If this response answers your concern, please mark it as "solved".
Distinguished Contributor
bjorn_fallqvist
10-15-2010 05:40 AM in reply to: benalain
I remember also having this problem. As far as I know, though, you can simply att the other BC as a prescribed displacement by use of a "custom" vector though. For example, if you set a prescribed displacement along the X-vector, I think the node is still free to move in the Y-and Z-directions. However, if you make a prescribed displacement with a vector of (X,Y,Z) = (1,0,0), the node will be constrained also in Y and Z.
I'm unsure how this works with rotations at the same node. Does anyone know if you can apply both a rotational and translational prescribed displacement at the same node simultaneously? I don't see why it shouldn't work...
Employee
S.LI
10-15-2010 05:49 AM in reply to: bjorn_fallqvist
I attached a MES model here.
Both BC and PD have been applied on nodes along the top surface.
Employee
shakeel.mirza
10-15-2010 05:51 AM in reply to: benalain
yes, as Bjorn explained, try using Custom vector!
Active Contributor
benalain
10-15-2010 06:04 AM in reply to: benalain
OK, i will try and let you know.
And i also remember that sometimes, it is better to input a custom vector than the X Y or Z one. But it shouln't be the case.
ALAIN
Active Contributor
benalain
10-15-2010 06:18 AM in reply to: benalain
Here is a model where i add a displacement in the Z direction (defined by a customer vector) and constraints also the X and Y direction.
And there is the error message
The file is here : http://www.yousendit.com/download/ZGJlU2Vxa0REbUpFQlE9PQ
Employee
S.LI
10-15-2010 06:28 AM in reply to: benalain
The BC is to constrain Tx and Ty, and the PD is (0,0,1), so there are incompatible on X and Y direction.
the PD should be applied on only Z direction, instead of "Vector".
Active Contributor
benalain
10-15-2010 06:45 AM in reply to: S.LI
OK i see i can not define the vector but only clic on scalar X, Y or Z
If i input the vector as custom, it is not accepted.
So what is the solution if the displacement direction is not in those global directions.
Employee
S.LI
10-15-2010 06:51 AM in reply to: benalain
Since you constrain, for example, X direction, your loads/PD on the same direction will make no sense.
For example, if X is constrain, and you want to apply PDs along both Y and Z. Then you have to apply them separately.
In another word, there should be two PDs in the model, one for Y and another for Z.
