Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Add material form matweb
2 REPLIES 2
Dan_Margulius
797 Views, 2 Replies
I would like to buy the database from matweb(gases) and put it an the Algor libs. The thing is that i download an example from matweb xml file and I cant find the way how to load it to the program after creating new library.
How to solve this?
R.
Dan
2 REPLIES 2
nvengineer
in reply to: Dan_Margulius
I gave that a try by downloading a sample library from matweb.  Here is how I did it.  From inside Algor, I went to Tools>Manage Material Library.  Then I hit New and gave it a name to create a new database.  After that I hit the arrow on the right side of the material window and went to import>xml and chose the xml file.  I attached a screenshot.  Good luck.  This was with 2010.
Dan_Margulius
in reply to: nvengineer
Got it , thanks.
R.
Dan
