I would like to buy the database from matweb(gases) and put it an the Algor libs. The thing is that i download an example from matweb xml file and I cant find the way how to load it to the program after creating new library.
How to solve this?
R.
Dan
I gave that a try by downloading a sample library from matweb. Here is how I did it. From inside Algor, I went to Tools>Manage Material Library. Then I hit New and gave it a name to create a new database. After that I hit the arrow on the right side of the material window and went to import>xml and chose the xml file. I attached a screenshot. Good luck. This was with 2010.
