Is it possible to bring a 3D sketch from Inventor into Sim. Mechanical to use as the skeleton for a beam model? I understand I can bring the vertices in as workpoints if needed but was hoping to skip this step since the connectivity is complex.
I tried launching the model with a 3D sketch only in it, and Simulation Mechanical told me there was no part in the file.
Thanks for any assistance.
Solved by AstroJohnPE. Go to Solution.
I do not know if it is possible. If it is, you would need to export the sketch to either AutoCAD .dwg or .dxf format. Those two formats can be imported.
