Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
3D sketch to beams
1 REPLY 1
nhahn
586 Views, 1 Reply
3D sketch to beams
Is it possible to bring a 3D sketch from Inventor into Sim. Mechanical to use as the skeleton for a beam model?  I understand I can bring the vertices in as workpoints if needed but was hoping to skip this step since the connectivity is complex.
I tried launching the model with a 3D sketch only in it, and Simulation Mechanical told me there was no part in the file.
Thanks for any assistance.
1 REPLY 1
AstroJohnPE
in reply to: nhahn
I do not know if it is possible. If it is, you would need to export the sketch to either AutoCAD .dwg or .dxf format. Those two formats can be imported.
