Hi all,
Can anyone please kindly enlighten me on how to generate a 3D helical curve in Algor?
I could not find any function to do this, hence I tried to generate the helical curve in other CAD software and exported it in IGES format. But Algor can only import the model in wireframe IGES format, which cannot be treated as meshable object.
I intend the mesh the helical curve with beam elements.
Many thanks in advance.
Best regards,
Pin
Pin,
If you want to create beam elements, then an IGES wireframe is what you want to use! You do not want to import a solid model if you want beam elements. A beam element is just a straight line at the centroid of the cross section. So, the CAD drawing should be a helix of one line. (If you can split the helix into smaller straight-line segments in the CAD, that will make it easier.)
After setting the "Files of type" on the Open dialog, click the "Options..." button before choosing the filename. On the IGES Wireframe import options, make sure "Import as 2-D objects" is not checked. Then choose the filename.
FYI: You should be able to import IGES files that contain a solid model. Under "Files of type", you should see entries for "IGES" and "Wireframe IGES". The first one is for the solid models.
Hi John,
Thank you for your reply. Actually I did open the model as Wireframe IGES and unchecked the "Import as 2-D objects", but couldn't proceed with meshing, please have a look on the attached image, which shows what happened.
Best regards,
Pin
"Mesh > Structured Mesh > Divide One Object"
