I'm going through the tutorial 2-D Weldment Model. Followed it step by step (actually did it twice) My results do not look like the results in the tutorial and I noticed it is because the welds are not "attached" to the horizontal member. You can tell by the way the mesh lines are not connected between the weld and the horizontal member.
I must be missing something very simple.
How do I get the weld connected here?
Solved by Sualp.Ozel. Go to Solution.
Here is what you missed:
Intersect the Vertical and Horizontal Parts
For the mesh to match where the welds meet the horizontal and vertical parts, we must create more intersections.
Best Regards
Sualp Ozel, P.E.
Product Manager
Digital Simulation
Autodesk Inc.
I had already done those steps, but for some reason it will not attach. Here is a small clip that shows the different lines.
http://screencast.com/t/wfRABnmd4T
When I run the analysis, I get this:
please create an Algor Archive file and attach it to this tread. I will take a look at this model for you and see what you are missing
When you mesh it, do you do each part indivisually or do you mesh it all at the same time? Maybe try this: In the FEA Editor, right click on the Plane 2 < YZ(+X) > plane and select 'Select All Sketches'. Then with all of the shapes highlighted go to Mesh>Create 2d Mesh then modify the values and click 'Apply'. This should create the correct intersections (for lack of a better word) for the mesh.
I looked at your Archive file and it was clear to me that you meshed this geometry prior to intersecting the lines.
But I also saw that you did infact intersect the lines as I recommended.
At this point All you need to do is to remesh your model and the mesh connectivity will be finalized. Please refer to the below image.
