Helius Composite Forum (Read Only)
Welcome to Autodesk’s Helius Composite Forums. Share your knowledge, ask questions, and explore popular Helius Composite topics.
Problem with Failure Envelope and First Ply Failure Survey
3 REPLIES 3
654 Views, 3 Replies
I've got a problem with "Failure Envelope" and "First Ply Failure Survey", for example, when i press an analyze button in FE it shows me the Analyzing window "Click abort button to terminate the analysis. Step 200 of 200 - Increment 0 of 0" and nothing else. In FPFS when i press Calculate i've got "First ply failure stresses" and that's all (see attachment).Other elements works fine.
Regard,
Pawel
3 REPLIES 3
dean.rose
in reply to: 229109
Hello Pawel,
Thank you for bringing this to our attention. It appears as though you have multiple Composite Design windows open. Is it possible there was a window with a message behind the others? I would be glad to continue troubleshooting this issue if you continue to have issues.
-Dean
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Dean Rose
in reply to: dean.rose
Thank you for response.I'm sure that there isn't additional hidden window behind the others. This problem appears on Windows 7x64, i've checked program on XPx86 (this same PC - second partitioning, ) with this same results.
Regard,
Paweł
david.veinbergs
in reply to: 229109
Paweł,
Did you verify that there are no problems with the lamina material property definitions?
-David
David Veinbergs
