I drew a CAD model of a water tunnel with my geometry installed in the tunnel using Inventor Pro 2014. I then used Inventor Fusion to add the water volume in the tunnel. Fusion could not open the .ipt file created by I.P. 2014 (it sent error reports to Autodesk) so I saved the CAD drawing in a DWG file which Fusion successfully opened. Fusion added the water volume and when I saved the result the dimensions of my tunnel changed from 60 inches to 23.6220 which is 60 divided by 2.54 making the dimensions decameters. Simulation CFD then ran fine but my Wall results have the wrong units. I tried to save Fusion results in the dwf file format with the correct dimension units and Fusion can not find it. Also I dimensioned the overall water tunnel features and locked them. When I saved this result the dimensions were changed by 2.54 again. Should Fusion be able to open an Inventor .ipt file? Must I always use metric units? Is there some file corrupted in my installation? I have reinstalled I.P. and Fusion. Any assistance would be most appreciated. Also, when Sim. CFD starts three or for licensing errors occur and then the job runs. Is this normal? Finally when I try to run a job on my "Cluster" Windows says something about a CMUD error.
Please help this newbie get up and running.
Thanks Mike
Solved by Jon.Wilde. Go to Solution.
