CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Why is the Knowledge Base not working?
11 REPLIES 11
Message 1 of 12
pwilkins
743 Views, 11 Replies
Every time I enter a search item, no matter how basic, I get no results.  What is going on with the wikihelp website?
11 REPLIES 11
Message 2 of 12
Jon.Wilde
in reply to: pwilkins
What link are you using?
I find the same as you regarding the Wikihelp - which I think is changing servers - hopefully someone else can confirm this.
The Knowledge Base seems to be working fine though, hopefully you can find your answers there.
Kind regards,
Jon
Message 3 of 12
pwilkins
Thanks Jon.  Here is the link I am using to WikiHelp.
http://wikihelp.autodesk.com/search?source=help&product=Simulation%20CFD&q=radiation&language=ENU
Thanks for the link to the Knowledge Base.  I will use it from now on.
Message 4 of 12
pwilkins
in reply to: Jon.Wilde
In looking through the link you sent, it still does not have all the information the former Knowledge Base had.  For instance, when I do a search for some explanations on Slip/Symmetry, all I get is a couple of links to some Service Pack updates regarding Slip/Symmetry.
Message 5 of 12
Jon.Wilde
One solution would be to use Google and view the results as cached, this works OK for me
Message 6 of 12
pwilkins
Jon,
Do you know when the WikiHelp page will be fixed so we won't have to use the Google search--->cached page approach?
Message 7 of 12
Royce_adsk
I agree sooner the better, but I keep getting different dates. So, I don't want to speculate.
-Royce
Royce.Abel
Technical Support Manager
Message 8 of 12
OmkarJ
pwilkins,
If you just want to refer the help documentation, why don't you just install the offline documentation?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21208244&linkID=18154757
Additionally, if you are dead set on going online, or need to access something on wikihelp that is not contained in the offline doco, try using this Google cache browser: http://cache.nevkontakte.com/
You can use the cache browser just as you use Google search or Chrome address bar. It is very efficient and quicker than searching in normal google and navigating from there.
Cheers
Omkar
Message 9 of 12
Jon.Wilde
OR - use the new help which you will find right here.
Currently transitioning over, but it should work far better!
There will be an official mailout soon as it is literally live today!
Message 10 of 12
Royce_adsk
The new help is actually in a different location. The one Jon posted was for Sim360 which is a bit different, but something to potentially check out!
http://help.autodesk.com/view/SCDSE/2014/ENU/
Royce.Abel
Message 11 of 12
Jon.Wilde
in reply to: Royce_adsk
This is a good point 🙂
Message 12 of 12
pwilkins
in reply to: OmkarJ
Omkar,
Thank you for the suggestions.  I didn't know there was such a thing as a cache browser.
