Discussion Groups
Simulation CFD
Active Member
0 Kudos
Vacuum volume
286 Views, 4 Replies
04-18-2013 11:32 PM
How i can create vacuum value in internal volume&
107 Kudos
Re: Vacuum volume
04-20-2013 12:16 AM in reply to: mrnfs
What do you exactly want to do?
OJ
Active Member
0 Kudos
Re: Vacuum volume
04-30-2013 02:58 AM in reply to: mrnfs
Heat transfer Simulation in vacuum.
Product Support
53 Kudos
Re: Vacuum volume
04-30-2013 11:13 AM in reply to: mrnfs
Depending on what you are trying to do, some have represented Vaccuum as a low density, low conductivity material.
For example if you were planning on doing a thermal model 'in space' we might create a custom fluid material with low density/conductivity so that we can still do internal radiation but not have any flow/conduction through the fluid itself.
107 Kudos
Re: Vacuum volume
05-03-2013 02:57 AM in reply to: apolo.vanderberg
Apollo,
I have observed that most CFD Solvers don't like materials with very low conductivity and density to represent vacuums, ie, they are hard to converge. Is there a value that you recommend as to how much low, without compromising the ease of convergence?
OJ
