the details of the problem occurred is discussed thoroughly in the following link:
https://www.dropbox.com/s/e281dvezluygpci/transient%20problem.pdf
please help me out to find the exact reason of the problem occurred.
Thank you !
Solved by Jon.Wilde. Go to Solution.
Link disabled, can you post the pdf here?
try this link please,im facing some problems directly uploading the pdf file to this forum.
https://www.dropbox.com/s/mr4lwwd6c4srg8c/transient%20problem.pdf
Thanks I have it
Some pointers:
Jon
thanks for your reply. so you are telling me that i can solve this without assigning any temperature boudary condition & initial condition for flow only in steady state and then i can assign boundary temp condition and initial conditions to run heat transfer (flow off) in transient mood. Am i getting it right??
Yes, although I'd set all the BC's up in the first place, thermal too. They will just be ignored until you turn on thermal.
Then just re-initialise the Initial Conditions and run the transient, easy.
